[Краудфандинг]Изучаю спрос на платы MyCPU
san020202
Благодарил (а): 44 раза
Re: Изучаю спрос на платы MyCPU
Сообщение san020202 » 11 июл 2018, 08:24:14
Arithmetic Logic Unit (ALU) Board
74HC00 IC48
74HC04 IC47
74HC74 IC49, IC50
74AC157 IC56
74HC541 IC51, IC53
74HC574 IC52, IC54, IC55, IC60, IC61
27C64 -or- 27C256, 100ns IC59
27C801 -or- 27C080, 100ns IC57, IC58
100nF ceramic capacitor C47, C48, C49, C50, C51, C52, C53, C54, C55, C56, C57, C58,
C59, C60, C61
10 pin header VA, VB, VC
16 pin header V0
20 pin header V5
Microcode Control
74AC00 IC10
74AC08 IC16
74HC08 IC9 Must be a 74HC08
74AC32 IC11
74AC74 IC14, IC15
74HC74 IC12, IC13
74HC161 IC6, IC7
74AC574 IC4, IC5, IC8
27C010 -or- 27C1001, 60ns IC1, IC2, IC3
100nF ceramic capacitor C1, C2, C3, C4, C5, C6, C7, C8, C9, C10, C11, C12, C13,
C14, C15, C16
10μF / 16V, tantalum C104
47 Ohm R1, R2, R3, R4, R5
470 Ohm R6
4.7 kOhm R29
14 pin header V1
16 pin header V0, V4
20 pin header V5
2*4 pin jumper block + jumper JP4
Signal Decoder
74HC138 IC17, IC18, IC19, IC20, IC21
47 Ohm R28, R30, R31
470 Ohm R27
100nF ceramic capacitor C17, C18, C19, C20, C21
14 pin header V1, V2, V3
16 pin header V4
20 pin header V5
Program Counter
74HC74 IC34
74HC161 IC35, IC37, IC39, IC41
74HC541 IC36, IC38, IC44, IC46
74HC574 IC40, IC42, IC43, IC45
100nF ceramic capacitor C34, C35, C36, C37, C38, C39, C40, C41, C42, C43, C44, C45,
C46
470 Ohm R25, R26
16 pin header V0, V6
Interface and Registers
74AC00 IC63
74AC08 IC29, IC32, IC62
74AC74 IC31
74HC74 IC64
74HC245 IC22
74HC393 IC30
74HC541 IC28, IC65
74HC574 IC23, IC24, IC25, IC26, IC27
LM393 IC33
10nF ceramic capacitor C105
100nF ceramic capacitor C22 - C33, C62 - C65, C100, C101
2.2μF / 16V, tantalum C103
10μF / 16V, tantalum C102
10 Ohm R13
47 Ohm R8, R9, R23
100 Ohm R18
470 Ohm R10, R11, R22
1 kOhm R31, R32, R33, R34, R35, R36, R37, R38
2.2 kOhm R12
4.7 kOhm R19, R21
10 kOhm R20, R30, R14
22 kOhm R16
47 kOhm R15
220 kOhm R17
SIL 8 x 4,7 kOhm R7
SIL 8 x 10 kOhm R24
D1 1N4148
Crystal Oscillator Q1, Q2
3 pin jumper JP1, JP2, JP3, JP5
2 pin connector (with cable) J2
DIN 41612 Connector J1
san020202
Сообщение san020202 » 11 июл 2018, 08:24:52
Список деталей для платы CPU (CPU 6502)
Желающие могут провести калькуляцию
Последний раз редактировалось san020202 11 июл 2018, 08:28:48, всего редактировалось 1 раз.
san020202
Сообщение san020202 » 11 июл 2018, 08:26:43
Далее для первого теста необходима плата с ОЗУ, на первом этапе достаточно одной.
Документация тут
http://mycpu.selfhost.it/guides-e.htm
san020202
Сообщение san020202 » 07 авг 2018, 15:57:04
Возвращаясь к теме по myCPU.
Вот такой набор плат для блока питания и платы CPU
Пока в единственном экземпляре.
Отправлено с моего A0001 через Tapatalk
Daniil Chislov 86
Опасный
Благодарил (а): 54 раза
Сообщение Daniil Chislov 86 » 06 сен 2018, 23:01:06
А может отечественные микросхемы и детали поставить ? А то мне свои "помои" и залежи не куда пристроить )
Daniil Chislov 86
Опасный
Сообщение Daniil Chislov 86 » 06 сен 2018, 23:04:01
Платы шикарные ! Если будет дешевле 6 тыщщ то я бы взял комплект для своих экспериментов.
А корзину как реализовывать будете ? Я бы хотел чтобы это как у пк ириша было реализовано (скорее всего сделаю так для себя и полностью на советских деталях
san020202
Re: [Краудфандинг]Изучаю спрос на платы MyCPU
Сообщение san020202 » 08 сен 2018, 12:58:23
Про корзину пока не решил. Платы я по случаю на барахолке купил, но судя по всему проектом не заинтересовались, по стоимости он не будет дешевым так как плат получается очень много.
Сообщение Павел Рябцов » 08 сен 2018, 14:07:23
Я предлагал всем, сделать MyCPU Compact но в ответ тишина.
san020202
Сообщение san020202 » 08 сен 2018, 15:53:45
Это не интересно, сам смак в множестве плат.
Сообщение Павел Рябцов » 08 сен 2018, 18:23:28
Ну не знаю, у меня их и так много, мне уже это не в радость...
